73moparman
Hello, i own a 73 plymouth duster, 340, 727.Everything up front is brand new...bushings, pitman and idler arms..everything. Does not have a sway bar..could this be my problem??
Not enough info. Photos of "stance" would be helpful AND IT COULD BE as simple as mismatched tires front/ rear.
What have you done about front end alignment?
More info: "How" does it not handle? Not keeping up with a prepped race Cobra is not a comparison, LOL
Does it wander, "cut" with bumps, play in the wheel, etc?
^^^sounds like the same one to me if I remember right.....alot of our classis mopars "wander" when going down the road...long story short, just a worn out front suspension and steering system. Want it to handle? Put a hotchkis TVS in it and replace all rubber with energy or prothane bushings and you'll be happy! In addition, V8 torsion bars doesn't mean much, you need AT LEAST a 0.92 bar to handle relatively well around corners with an all iron V8 under the hood imo...
Yes sirs that would be the car. I replaced everything up front all new rubber bushings..fixed the lower control arm sleeve and got it all aligned by a shop in town. I just dont know what i should try next. Tires? Sway bar? Shocks? I just wanna get that sway out of there..its dangerous to drive...
Put a front sway bar on it, get some new tires for the front.
Those 2 things I would do regardless of whatever is going on.
Oh, and put in subframe connectors.
Ok i will get it to the shop and get the caster set to the max and go from there..thanks for the infoCaster Caster Caster. What 67cuda360 said. Get the max + caster you can, maybe 2 degrees without any other changes.
Before you change any hardware changes, double check the caster. This made the single biggest difference in my 73 Duster's straightline driving. Before I had it adjusted, I had 0 degrees, and the bu,p sterring was scary!
If that does not help, use moog offset upper control arm bushings, and get the max amount of caster you can. 3 degrees would be nice.
