M MoparMatt77 Active Member Joined Jun 17, 2017 Messages 27 Reaction score 2 Location Delaware Jun 17, 2017 #1 Whats the best option for lowering a 73 Duster, kit? Brand? Fabrication?
M MoparMatt77 Active Member Joined Jun 17, 2017 Messages 27 Reaction score 2 Location Delaware Jun 17, 2017 #2 bump
J Jim Lusk Well-Known Member Joined Mar 8, 2006 Messages 6,209 Reaction score 3,154 Location Fresno, CA Jun 17, 2017 #3 Depends on how low you want to go. The front end is adjustable. The rear can use lowering blocks.
M MoparMatt77 Active Member Joined Jun 17, 2017 Messages 27 Reaction score 2 Location Delaware Jun 17, 2017 #4 Jim Lusk said: Depends on how low you want to go. The front end is adjustable. The rear can use lowering blocks. Click to expand... Well I'm used to pickups so when you go higher it's usually level, 4, 6, or even 8". Lowering A Duster I figure 1 or two inches, is the QA1 suspension kit good? I'm going for a semi pro touring build
