Penstarpurist
Been working on getting our duster ready for paint. The passenger door was wiped out so we pulled it and put a straight door on, rebuilt the hinges with new pins as the old door sagged bad also. Installed the replacement door and it sags worse then the old door did, won't latch without holding up the door. Even then won't shut all the way. So in a desperate attempt to see what would make it work I slipped a 1/4" steel plate in between the bottom hinge and the door and like magic it closes almost perfect and doesn't sag. I know the shim may be an answer but not a solution. The car has been beaten and abused. I think even offroaded or jumped. Not a straight panel on it until we fixed it. Any thoughts on what to do? Should I just make a full plate shim and tack weld it in place?
