73 Scamp window help
73 V8 Scamp
Member
Independence mo
I have 1973 scamp 2 door hardtop and have a broken rollup quarter window. I am trying to find the hardware to replace the glass. I have the 2 bolts but it looks like their is a spacer and some kind of adhesive . Where can you find these pieces , in the manual the only car that type is close is the Barracuda...
Thanks
This is what my Hardware looks like for the quarter window and is the same on both sides
All I know is there will be some sort of isolator anywhere that metal would touch glass. Sometimes only a piece of felt paper sandwiched between. I just substitute as needed with felt paper, plastic washers, short pieces of fuel hose, whatever. RT Specialties might have reproductions of exactly like the factory used.
yep - sometimes you have to improvise -- hell, often times you can come up with something that works better than they did it back in 1971
