'73 Sport Amateur Touring!
Graminizer
The "Big G"
Chilliwack, BC, Canada
Hey guys,
I seen someone else on this forum use the "Amateur" instead of "Pro" so I thought I'd steal it.:D I have been a member here for awhile, and I'm finally getting started on my project. It's a 1973 Dart Sport that I picked up 3 years ago. I plan on doing it like a pro touring/cruiser. No need for drag racing for me. It was disassembled when I got it, but I have a '76 parts car that I have as a template. Here are some pics of when I brought it home.
I'm the big guy in the pic!
My son and I prepped and painted the engine compartment. I love this color! Not too concerned about the drips on the frame....I will be repainting it black.....same with the K frame......it's gone altogether!
Trunk view before I start into my mini tub!
Spent the morning pulling the old 8.25" out! Now time for lunch!
Would you sell them rear shocks? And you wouldnt happen to have an extra floorshift column layin around would ya?
I used DR.Diff axles for my Dart and they are great. Would definately buy another pair from them.
Should be interesting. Do you have wheel & tire sizes selected?
http://www.forabodiesonly.com/mopar/showthread.php?t=196797&page=3
Check out post #64.
The 1st & 2nd are a 275/45/20, and a 325/50/15 tucked up high. The fenderwell is removed to the quarter.
Next is the nice low tuck that I would like. Then the reality check - showing what is possible without notching the frame. The last one shows measuring to place the wheel center 5" below the frame, which I calculated to be the minimum needed.
Coilovers may get you a little lower as I was leaving 3" for suspension travel.
I finally picked up a welder the other day. I just need to finish wiring the shop for the 220V and I'll be set!
I picked something special up tonight.......an original, not a repro!
Need to drill for the mounting holes and figure out the size of hole needed in the hood.
On my hood I am just triming the center triangle out. Maybe down the road trim it so I can stick my 14x4 inch air cleaner through it
Nice project, off to a good start. Keep the pics coming :toothy8:
Looking Good!
The Dodge Dart Sport Was My 1st Mopar And I Miss Mine...
Managed to spend some time in the shop today......continued with the mini tub on the passenger side. Almost ready to tack the wheel well back in place. I just need to make a few more tweeks and she'll be ready.
That's progress there! I pull parts off K member rather than pulling it all at once. Friggin too clumsy and heavy for me! :)
