74 360 4speed duster returns to family
Electric. I believe it is 3 position.
Could you verify?
Looks like you have a 2 speed wiper motor (like I do), which would make sense with a 3 position (off/slow/fast) switch. But several months ago someone said they had never heard of a 2 speed motor switch (with 3 positions) that had the option for an electric washer motor.
Sure enough, when I messed with mine I found that I had a 4 position switch running my 2 speed wiper.
Just curious if yours is similar or if you in fact have a 2 speed motor switch with the electric washer function.
Thanks!
Could you verify?
Thainks!
I get
Could you verify?
I get it back tomorrow I will have a look.
It is alive!
74 duster 408 stroker
Short Video of the car. Just got it running again. I will sent a longer one when I get it back.
Could you verify?
Looks like you have a 2 speed wiper motor (like I do), which would make sense with a 3 position (off/slow/fast) ]
Could you verify?
Thanks!
Yep you are right 4 position. Although the 3 speeds all seem to be the same speed. Ha!
