74 dart 383 , dana 60, 727 tf. in florida
74fldart
orlando, florida
Rating - 0%
0   0   0
1974 dodge dart , all work done during 2008, 2009 and 2010
Body color is silver, interior is black, bucket seats, no back seat.
Hood as a six pack type scoop installed, hood is black
Engine: 1971 383 , steel crank, comp. ratio 9:1 ,engine had been rebuilt when I bought it in 1998 .
Double roller summit timng chain true roller, new
452 heads, milled .060 , intake side milled also , New valve springs, seals, 3 angle valve job heads have been ported fully and intake man. is Port matched steel , head gaskets
Demon 650 road demon carb with adjustable secondary pod , fuel regulator and braid hoses , new msd blaster coil , mopar performance parts distributor, msd 6a ign. Box.
Carter hi perf. Fuel pump, new
New comp cams extreme enrgy 268/ 488 lift cam and lifter set.
699 oil pan w baffle installed, dr. side torque strap 1/3/4” headers and new summit 2.5” exhaust system installed with dumps.
Holley street dominator intake , port matched to heads
New 100 amp alternator from tuff stuff. New battery 08/2010
New aluminum radiator., new water pump, rebuilt hi perf. Mini starter
Transmisiion is a 727 torqueflite all rebuilt
New Torque converter from trans, specialties 2400 stall
New bushings, seals bands, sprag rollers and springs, thrust washers,
Hi perfornace clutch discs and steel plates. Trans go 2 shift kit installed , heavy strut band
3.8 kickdown lever other hi perf. Mods done to case, valve body , etc. trans cooler installed., deep pan, installed. new urethane mount
rear end: dana 60 with 4:10 gears rebuilt w new bearings, new Yukon axles w green bearings
New driveshaft from strange, chrome moly w 1350 yokes , new yokes on both ends
Hd ubolt yoke kit, posi all rebuilt new mopar axle housing ends, new spring perches
2 new rear tires new rear brake drums, shoes and hardware and cylinders , rear shocks replaced.
Wheels are centerline style alloy 15 x7 w 4” back spacing , these were used wheels
Rear tires were new 255/60 tiger paw , front are 215/60 used but very nice condition.
Front brake calipers were rebuilt. New brake hoses front and rear, front end busings replaced along with ball joints .
New gas tank, and sender unit , drive shaft safety loop, battery cutoff switch in bumper, trunk mounted battery
New gauge set inside car, nice set of black bucket seats, new b&m starshifter ,
Rear seat is removed and steel sheet installed , interior panes and dash are pretty nice And black in color, headliner is good , it has a cut to fit cheap carpet on the floor .
Paint is ok for a driver but has had body work and bondo, if you want a real nice body it would need to be redone for shows etc. car had rust but it was repaired. Front floor pans were repaired with new steel put in. this is just a street/ strip type car. licensed and street driven.
All a/c heat system has been removed. No radio.
The bumpers have been lightened with the crash reinforcing bars removed , and bumpers tucked in more, bumpers are painted black now.
asking $6500.oo for it, im in the orlando, florida area. reach me thru pms if interested.
sorry i havent checked in lately, here is a couple more
