74 Dart engine wiring diagram
Electrical and Ignition
  1. torredcuda
    torredcuda Well-Known Member
    251
    8
    Jan 19, 2005
    Local Time:
    1:40 PM
    Anyone have a diagram for the engine wiring, 318 car?
  2. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    45,658
    13395
    Oct 14, 2010
    Idaho
    Local Time:
    5:40 AM
    You need a 74 factory shop manual. 73 is similar but there IS differences, including the ignition interlock.
    You can download a 73 manual from MyMopar (which came from the guys here)
    and MyMopar also has "aftermarket" wiring diagrams. However, they don't show the seat belt interlock wiring, and leave out options
    If you still have the interlock "box" (look for a small box under the hood with a reset button) Cut and splice the two yellow wires together
    http://www.forabodiesonly.com/mopar/showthread.php?t=14304
    I started to scan the 74 electrical but was happy with the results, and don't have it yet.
    The thing is, starting in 73 and newer, the wiring is all chopped up in the diagrams. If you can post specific questions, we can waltz through it.
    To get an idea of how this works, start with the 73 manual in the meantime.
  3. Rapid Robert
    Rapid Robert Well-Known Member
    1,097
    136
    Aug 6, 2006
    Lincoln Nebraska
    Local Time:
    7:40 AM
    www.mymopar.com reportedly It is missing a few circuits here and there but I've always had VG luck with it but check it out & see if it ans your Q. When jumping back & forth between the (2) schematics for each one, as each one is "cutoff" on the one side, it works good to open both up then minimize one at the bottom of the computer screen then pull em up back to back to match up the "ends", you'll see when you get there. Is there a specific area there under the hood that you have a Q regarding? Maybe the sharp guys here can ans it for you.
  4. torredcuda
    251
    8
    Jan 19, 2005
    Local Time:
    1:40 PM
    Just got this car and there is some "interesting" wiring under the hood. the PO put some relay system in to control the Edelbrock carb electric choke, an MSD box and coil were added and I`m sure I`ll find I few more things to fix. Mainly need to wire the choke back up and figure out where a few wires go or what they are for, passenger side intake manifold area. I`ll check out My Mopar as well.
