[Found!] 74 Duster 383 Headers
64plymouth
wisconsin
Rating - 0%
0   0   0
I bought a 74 duster body for a father/son project. We are putting a 383 in it and need some headers tri-y or full. This will be a street car so no fenderwell headers. Got wiring. Thanks Mike
I bought a 74 duster body for a father/son project. Someone unplugged all wiring under hood. So I need all wiring that plugs into bulkhead. Also we are putting a 383 in it and need some headers tri-y or full. This will be a street car so no fenderwell headers. Thanks Mike
I might have a harness setup
I'm sure that you know that there were never any Duster models built with a big block engine. This means that any stock harness that you get will need modifications. The distributor and coil are at the front of a big block, at the rear of a small block. The ballast resistor and voltage regulator wiring are also a moving target as some were on the left inner fender near the master cylinder and some were on the right side near the alternator. A slant six harness has the longer distributor and coil wiring but the oil pressure wire is also long, it would need to be shortened or just bunched up and taped.
I have a very nice harness out if a 74 225 car and it will be closer to big block than a sb harness....120$ shipped to lower 48.
I don't want to sell just the engine part tho. and can only take a postal money order.
Lmk if u can use it...thanks
Yes I know. I just want something to start with. This is a low buck first car. If he wants to make it nicer in future it will be on his dime.
