airkiller
MOPARS Rule
Ok guys, here is the scope. I have a 74 Duster that I have decided to convert to 4 speed from a auto. It currently has a 318/ 904 combination in it and I wish to remove them and install the 4 speed in place of the 904. I am going to rebuild the 318 and put it back in for now but maybe some day I can step up to a 340 as well. But for now, I need to get some help with this part of the project. So far I have a A body short shaft 833 that I just picked up with the bell housing. It has a shifter plate on it but no shifter, shift rods or shift arms. During this project I am also converting to bucket seats with the console. I need to find the following parts and or part numbers.
Shifter:
Shifter Handle:
Console plate for 4 speed: ( I have the auto plate. Willing to sell/ trade)
Shifter rods:
Correct shifter mount plate:
4 Speed Tunnel Hump:
Things that I have
Flywheel
833 Short shaft
Bell Housing
Questions:
1) Can the same drive line be used?
2) WHat Thow out bearing PN# to use?
3) Can same cross member be used
4) What trans tail shaft mount to use?
5) What clutch and Pressure plate to use ( not going to race, but what lasts
If anyone is looking for a 904 with 10,000 miles on it, I will trade it for parts I need. I can be reached by phone also at (916) 925-4917
Thanks in advance for the help.:cheers:
Shifter:
Shifter Handle:
Shifter rods:
Things that I have
Flywheel
833 Short shaft
Bell Housing
Questions:
