'74 Gold Duster
Kegan B
IN
Some probably recall this car, we bought it some time back. In 2016 it ended up being rolled over, decided to finally pull it out and fix the body on it. Once getting the carpet out found out the floors were pretty much gone.
Just got back today with the biggest piece I currently needed to start on it.
I take it you have some mad fabrication skills! 65
take your time and break the welding down into separate 'projects' and you'll be fine.
neil.
Worst case the vinyl top will hide it, if it comes out well I can always leave it off though.
Pardon me while I cringe! Looks like a lot of body work. Good luck.
It's not all the bad rails, rockers, trunk floor and most of the body is rot free. It's just in the roof and front pans for the most part.
Put the floor in it first, then tackle the roof.
Cleaned it up the other day, probably start cutting on it sometime next month.
