The bearing races for the carrier are the same for all 3 housings; pinion bearings are all different, I don't beleave you're gonna find a combination of bearings, races that will allow you to swap pinions around between the different housings. If it were possible, some one would know how to do it, information would be out there.
$64,000.00 question is WHY do you want to try this?
That's about what I'm running with 3.55s, a stick, and 295s, but with a 742. No worries on the street, even with a CFII and a GVOD pounding on it. I did shred the 7290 joint tho, and tore the straps on another. The cure was 1350 joints and a u-bolt yoke.Good to know! all i hear is cap and teeth.
I'm going to put about 430 HP in a 3700 pound car with a 741. slick, but auto.
The carrier bearings are specific to the type Sure Grip you are using The Clutch type uses 25520/25590. The cone type uses LM104912/ LM104949 bearing race. All three cases are easy to find. Just use the appropriate case.
I have 3 free 741 case and "0" 742/489s If you want to relieve yourself of one of them, I'm ready to give you my address!!!!Why is my statement almost correct? I never said gears for the 3 cases are available anywhere, I said cases! Which one do you need? I can send you 5 of each! If you have gears for a 742, just get a 742 case. Why make this harder than it needs to be?
They snap all the time at the yoke stress riser. Had plenty of them still attached to a driveshaft. Happens with the 742/489 pinions.
You got me thinking here.........if the diameter is the same at the yoke for all three. then there is no power advantage, at this point, right? I when and looked, and it show a 10 spline for 742 and 29 spline for 489 didn't say what the diameter was.
just to add some more info.
I found a site that stated that all pinion Yokes are interchangeable as long as the spline count is the same. apparently the 489 had a coarse spline with the early production of them.
In other words the yoke is the same side for all three........
I didn`t read all these posts, but they have diff diameter pinion shafts don`t they ? the 489 even being tapered, the 742 was larger diameter than the 741, which is the weakest of the bunch.From what i have researched so far. 741,742 and Early 489 had a 10 spline. 741 used a 7260, 742 and 489 used a 7290 with a strap. You can get a 7290 yoke, with and upgraded u bolts for 10 or 29 spline. Top of the line 1350 that comes only with u bolts to hole on the cap, with 10 or 29 spline.
I think/ thought that my third member had the 1350 yoke........because it has u bolts holding it on. It my only be the up graded 7290 yoke. I'm going to have to jack my car up, and see which one i actually have.
