75-76 Aluminum 833 4 speed Overdrive trans questions ?
How much horsepower will a stock aluminum 75-76 stock 4 speed 833 overdrive hold
  • 300
    Votes: 2 28.6%
  • 350
    Votes: 1 14.3%
  • 375
    Votes: 1 14.3%
  • 400
    Votes: 3 42.9%
  • 450
    Votes: 0 0.0%
  • 500
    Votes: 0 0.0%
  • More
    Votes: 0 0.0%
  • Total voters
    7
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
I have 2 identical aluminum 75-76 aluminum a body 833, 4 speed transmissions, one complete with factory shifter and rods
1. How much hp/torque will they handle
2 How much with modifications
3. Weak links/poor engineering
4. Availability of parts
5. Reliability/durability
6. Value
7. Requires its own bell housing ?
It depends on the clutch and the tires.
Put some bite on it and I can break every part from the input back with 240 HP.
Trying to put a power estimate on what a transmission will take is a fools errand.
The OD 833 isn’t much different than a non OD 833. It will take whatever you give it with the clutch you use and the tires you run.
The aluminum case is made for slant sixes and 318s with 2.76 gears.
I would trust the cast iron case way more because those are the same as the beefy 60s stuff they made at a time when stuff wasn't made skimpy.
Put that aluminum case behind a 318 2 barrel or slant and enjoy the decent gas milage until the aluminum case decides to come apart on a lonely stretch of highway.
Every aluminum case I had was junk and came apart on the highway even behind a slant. Right now my slant six car has a '75 cast iron OD and that has been collecting miles for years.
There's no option to vote 100 horsepower which is still probably too much for an aluminum case
Mehhh, maybe 55 horsepower at the rear wheel in rain while peeling out around a corner.
So... You're saying I'm a fool for trying to determine if a transmission is strong enough to stand behind an engine. Interesting, Mopar 488 V10 truck engine had more hp potential in it, but was limited to just shy of 500 lbs torque because the trans they wanted to use could only handle 500 lbs.
If you say that I'm ignorant , that is, I just don't know, and Iam seeking enlightenment from others, that would be correct.
Get the counter shaft bore in the aluminum case bushed. That's about the only weak point. The case wears and allows lateral movement of the counter shaft and causes the gears to misalign. If they do it under load, blewy. Once bushed, the over drive almost rivals the non OD unit for strength.
If that’s what you read that’s a YOU issue.
Take a look at every Borg Warner T-10, Super T-10, Saginaw and Muncie out there. They are ALL aluminum cases. Do they fail? Yes. And mostly it’s because the clutch kills the gear box.
Its pretty easy to explode any gear box when you run a junk clutch, which BTW those are rated by HP too.
I’ll say it again. Trying to determine if a gear box is strong enough for the application using HP or torque as a measure is a fools errand.
I can take any transmission you pick thats rated for let’s say 500 HP and shred it with 300 HP. I can also take that same gear box and run 750 through it and not kill if IF the clutch is correct.
You, like others (put on your big boy pants and don’t be offended) look for an easy answer to your question when there isn’t one.
You are starting with a false premise and building your dogma on it.
You need to learn clutches and clutch tuning and THEN figure out what the gear box will take.
At a bare assed minimum you need a clutch tamer to make the gear box live.
Again, you can break any transmission with much less power than it’s rated for. That rating system is a dumbed down, inaccurate method used by companies to seek you their garbage without teaching you anything.
Of course, when their junk destroys your gearbox, the clutch morons will tell you the gear box was junk.
BTDT.
6. Value
Parts are no problem. The O/D can be 26 spline output or 30 spline output. I personally prefer to swap the aluminum case for an early 64-67 cast iron standard 4 speed case with a 307 front bearing and run the standard countershaft as opposed to the O/D countershaft. Been running one in the 66 Formula S for years giving my 3.91 gears a highway ratio of 2.78. The bell housing also depends on the front bearing, 307 or 308. Some of the early O/D used a 307 front bearing. And because of this, all you have to do is swap the standard front bearing retainer onto the 307 case and pop the trans into any A-Body bellhousing. I know of at least one O/D gearset in a 440 6 pack doing fine. He also just added the O/D gear set into his original 4 speed case. He may have had to grind clearance in the case for the large O/D gears. The early cases have worked fine, so far, without grinding clearance.
Parts are no problem. The O/D can be 26 spline output or 30 spline output. I personally prefer to swap the aluminum case for an early 64-67 cast iron standard 4 speed case with a 307 front bearing and run the standard countershaft as opposed to the O/D countershaft. Been running one in the 66 Formula S for years giving my 3.91 gears a highway ratio of 2.85. The bell housing also depends on the front bearing, 307 or 308. Some of the early O/D used a 307 front bearing. And because of this, all you have to do is swap the standard front bearing retainer onto the 307 case and pop the trans into any A-Body bellhousing. I know of at least one O/D gearset in a 440 6 pack doing fine. He also just added the O/D gear set into his original 4 speed case. He may have had to grind clearance in the case for the large O/D gears. The early cases have worked fine, so far, without grinding clearance.
Wow, great information, exactly what I was hoping for !
BTDT.
Ok, so what do you say about Tremec T56 that's rated at 1200 hp, or the Richmond Gear that rate to 600 lbs of torque, etc. I was hoping that others would post what amounts of hp and tq that they had used successfully on an aluminum overdrive.So , again I'm ignorant on the subject, I don't know.Im seeking advice from those "in the know", been there, done that.
I would not run an Aluminum case without steel countershaft bushings. As posted above the case is pretty much shot after 100,000 miles behind a 225 /6. Call Brewers or Passon.
Get the aluminum case countershaft bushing taken care of and there is no issue for street use. I wouldn’t recommend power shifting into OD, but since you picked the 833 o/d I assume you won’t be racing with it.
the achilles heel is the counter shaft bore and once that gets sloppy the interface betwixt the gears turns into a boxing match in a phonebooth. somebody locks it up with somebody else and ka-pow.
getting that bushed is the best step.
they put those transmissions is vans and trucks behind V8's so it'll take some abuse. but side stepping the clutch on a motor with a loader's worth of torque and fat tires would be the death of most anything.
I'm saving parts to build an economy package engine in case gas gets and stays crazy. I have a stock bore 273 (68), an Edelbrock 318 Street master, and a 400 cfm AFB. I have a 2.94
8 3/4 carrier, in conjunction with the .79 OD ratio should be about a 2.30 final ratio, which should put me at 2000 rpm at 80 mph
I don’t think you would have any issues, I’d be curious to see the MPG you get from that combo. 25 mpg highway should be cake.
that is an incredibly low final ratio, what are you planning on running ignition wise to get enough timing at cruise?
I don’t care what they say. The clutch and bite is what kills transmissions. What you don’t understand about that confuses me.
Or, you want to believe the dumbed down understanding of how clutches work and why most transmissions fail.
ITS THE CLUTCH
I run on the street
But my car has run 93 in the Eighth, so no slouch. By the trapspeed and weight, this comes to ~430hp.
It has run at up to 195psi cylinder pressure.
I have, in the distant past, run the big output shaft, in the A833od, in the alloy box, both with and without the C/S bushed, behind the 367, and the only thing that I could break, was the tiny overdrive gear. and every time I broke one, it was by accident; in as much I forgot to get off the gas!
Yet;
in one case, I ran this very same box behind a lowly 318, and she stripped the entire front end off, losing all forward motion, lol.
So far, I think I have 3 or 4 busted A833ODs, and 1 or 2 spares not yet ever installed on anything I own.
The best advice I can give you is that you install some kind of overdrive lock-out, cuz in the heat of battle, you will likely forget that this box is a 3 plus 1 , and zing the od gear off. and when it goes there are at least 21 teeth flying around and nobody can predict where the will go. If they go thru the front drive gears, which are right beside it, you will be walking. I didn't do that, and wiped the last one out, about 4 years into the program.
That was when I called it quits and ordered a Commando gear-set from Passon, together with one of his alloy boxes and an alloy cover. That was around 2004, and I haven't ever blown anything else up.... besides clutch-discs... lol.
MSD 8680 adjustable timing from the dash in conjunction with MSD6AL box, also mp dizzy, rates and advance accessible through the breaker plate, adjustable vacuum advance
6. Value
As to these questions;
1) since my engine seems to be making over 400hp, and more that in torque, I gotta say at least that much, lol.
2) there are no mods that I know of, to increase reliability
3) the mainshaft od gear is the weak link.
The poor engineering is the exceptionally wide ratios. 3.09/.73=4.23= 423% range. This is too much, IMO, for just 4 gears. I installed a GVod behind it and started splitting gears, for Seven useable gears. IMO, this was two gears too many, lol. But it did allow me to run those broken boxes for many more years, as six-speeds
4) I buy spares at swapmeets
5) leave it parked in the garage and never worry
6) I have paid as little as $50, and as much as $100. When yur walking, $400 will be cheap.
7) yes and no. the factory retainer is 5.125od and requires it's own housing. I have heard that the retainer can be cut down to the next smaller size, but I have not seen an SBM housing that ever had the next smaller hole. So then you got lathe the hole out to fit your cut-down retainer; and then you gotta bring everything back into alighnment by dial indicating it and moving it to where it needs to be, then you still gotta figure out how to make it stay there.. BHs are cheaper by far, than going thru that rig-amarole.
8) BTW as a streeter, and at WOT, you will be mostly concerned with Second gear. The right Roadgear to run with a stout 360 is about 6.50 to 6.80. The gear in the trans is 1.67, so then the rear gear will need to be ~6.70/1.67=4.01, rounds up or down to 4.10s/3.91s. I recommend the 3.91s, which will get you 65=2310 with 27" tires.
Now, the starter gear will be 3.91 x 3.09=12.05, which is way more than any 360 needs. But worse, IMO, is when you shift.
In my combo with 3.55s;
Around town I usually shift at ~2800, which is 20mph. With the Commando, shifting into Second brings the Rs down to 1740, and my 367 easily pulls that. But when I had the od box, the Rs dropped to 1510, and of course, the engine had to struggle for a bit. To overcome that, I had to rev it to 3220 to get back to 1740 on the shift. No big deal right? Well except that 3220 was now ~24mph.
But at WOT, shifting at 5500(40mph), the Rs dropped to 2970.... that's a serious drop, and now the car is getting into wind-resistance.
so then, in the combo of A833od and 3.91s, whatever engine you have in there, it's gonna need some balls to pull hard from 2970.
Finally, with 3.91s and 27s, 2970 is 36mph, 4500 is 54mph and 5500 is 67mph, so this is a pretty good Second gear for city driving, with the right combo of cam, to cylinder pressure, to cubic inches.
The od ratio is .73.... not .79,
and I can tell you this, your 273 is not likely to make any better hiway-only fuel mileage at 65= 1740 than at 65=2200............. because the stock-type distributor cannot deliver enough ignition timing at 1740, but can, at 2200.... albeit barely.
Furthemore, the engine will struggle longer and harder to get up to speed with the 2.94s and 1.67 Second gear.
Furthermore, in town, in Second gear, and 2.94s, 30mph is ~1830rpm. If the engine even pulls your car at 1830, it's gonna take considerable throttle to do it. If it gets up on the mainjets, say goodbye to fuel mileage.
Furthermore, trying to get to cruising speed using Second gear, is gonna take a lot of throttle initially, and or, for a long time, and so ........ say goodby to fuel economy......... again
The 273 has the potential to be a great lil fuel-miser, but IMO, you are not working the angles right with this combo of A833od and 2.94s.
This trans/gear combo will need a stinking boatload of cylinder pressure to even tickle fuel-economy, and it's almost not possible with a 273. I mean with closed-chamber iron heads, even shaved, you are limited to about 160/165psi on best gas, and Ima thinking you want to run 87. This will NOT, IMO, be possible with this trans/gear combo. or if you do swing it, it's gonna be more expensive than it's worth.
IMO, with this combo of trans to gear, you're gonna need very high cylinder pressure to be efficient, and that points to an alloy headed 318, at least.
If I'm right, then you have a decision to make, which is this;
to keep the 273 she'll need one of two things, either; gears closer together, and/or not handicapped by the 2.94s .
Since you already have the 273 and the 2.94s, my vote would be to get a close-rario/standard-ratio, 4-speed with a lower first gear ........ like the commando, and then slow down a little.
2.94s will get you 65=2380 with 27" tires. This will require about 56 degrees of timing to be efficient, which is doable with a stock-type distributor. The Commando 3.09 low gear gets you a starter gear of 9.08 which will get you to 3600=32mph, on the 1-2 shift, the 1.92 Second gear will be 2240, and the 273 can pull that all the way to 50=3570 rpm. On the 2-3 shift, the Rs will fall to 2560, and third will get you 65=3330. and then Fourth drops to 2380.
Now; gather up the data. Your powerband for this, has to be from ~2240 to max of ~3600.
So if you build your engine to work in that zone, getting fuel-economy is a sure thing.
BTWs,
> the cam for this is the stocker, which may already be in the engine. But if not, there's better ones to be had,
> a 318, driven the same way, in this circumstance is likely to get BETTER fuel economy because you can build it to a higher pressure with way less money, and with the higher pressure, it will accelerate harder on the same throttle-opening. Or said another way, it will accelerate the same as the 273 with LESS throttle-opening. In this case, less is more, lol.
Here's the thing, the 273 can be made to really sip fuel, but it's not something that you can just throw together. Whereas pistons for the hi-pressure 318 are easy to find.
> pressure can be made three ways; your options are; cubic inches, Static compression ratio, and intake valve event timing. Pressure is directly limited by the onset of detonation, which is directly related to, the octane of the fuel you want to burn, and together with the temperature in the combustion chamber.
> While getting the 273 to run 80@2000, and still get fuel-economy may be possible, IMO, it will Not be possible on a Throw-it-together budget.
> however, this does Not preclude you from throwing it together just see what happens if you already have all the players.
I did exactly that from winter/2000 to about 2005 with my winter-engine; a smog-era 318 with a quick freshening, the A833od and 3.55s. But wait, with a GVod behind it, Yes it pulled 65=1600. But I installed a Thermoquad, a small-port Iron intake, and headers. and I wasn't after fuel economy. Rather just something to drive while I freshened the 367 every winter.
Not once did I check the fuel economy, mostly cuz the daily commute barely got the engine warm.......
Mr. James I could be wrong.
BTWs,
Damn, a treasure trove of info at my fingertips !!!
I'm happy the a very mild 68 273 will have fire thru it after all these years. My plans are to heavily research and call cam companies to grind a cam that maches the Edelbrock Street master intake which has great tork but is all done at 4500. might cut the stock heads to 9:5 1, etc
I have found propane carburetors that will work. I don't give a damn what the fuel situation is, I'm going to cruise !!!
I run on the street
Yet;
Well here you go @Brooks James. This is what I’m talking about.
AJ is trashing 3rd gear, not because its an OD gear, his CLUTCH is KILLING it. Exactly what I’m saying.
I had a stack of non OD 3rd gears and junk clusters from garbage clutches. And you know what dies first every single time? THIRD GEAR.
You now have living proof that clutches kill gearboxes.
Thats exactly what killed his boxes. And it will kill ANY transmission you stick behind a junk clutch.
I’m out.
Brooks- I want to put one behind my Slant. Do you want to sell one?
