they’re rated at 85lbs and I run them at 58psi. I finally got my 2nd pump wired and programmed to come on under boost but haven’t tested yet.Have you made any progress with fuel? To the best of my knowledge those decapped injectors flow around 96lb/hr or 1000cc’s. Are yours smaller? Have you run them at 58psi base pressure?
I just watched that episode last night.very interesting. I’m running the Snows Boost Juice.Are you actually running water/meth mix? You should watch the engine masters episode where they tested a bunch of different stuff regarding it. The water/meth mix lowered the IAT but made no more power. Running straight methanol, dropped the IATs and made a bunch more power. The theory was that the water helped cooling but displaced enough volume that no more fuel could be added. It was eye opening for me.
Easiest way to address a rich condition is to add more boost !!And to add another variable to the mix I added a 2nd water/meth nozzle (#10) at the base of the intake elbow. I’m running a #5 at the compressor which was a little undersized by itself. I haven’t tuned any with the new nozzle but just on a few test hits it’s making the AFR about .3-.4 points richer so I’ll probably have to tune around it.
It’s activated by the ECU based on RPM and boost PSI. The water/meth is more of a crutch for upper psi when I start hitting the limit of my injectors. I also plan on mixing in some 93 and shoot for an E70 or lower mix to get a little more mileage out of the injectors and the meth will be extra insurance against detonation.Easiest way to address a rich condition is to add more boost !!
Can you control the water/meth with the ecu or are you using a Hobbs switch? Looks awesome!
If you need pictures now the car is home for a bit can take which ever ones you need. Just let me know.Also started mocking up my summer project (triangulated 4 link). This one’s gonna take a lot of head scratching and mocking up but I think I have a good plan. Measure 50 times, cut and weld once.
View attachment 1715935282 View attachment 1715935283 View attachment 1715935284
Thanks! I’ve saved a bunch of pics of your suspension setup already as references. The big challenge is the upper bars. I’m trying to get as much adjustability as possible, avoid making the bars too short and packaging all of it in that tiny space above the axle. Pics of your upper bars and the anti roll bar setup would be great.If you need pictures now the car is home for a bit can take which ever ones you need. Just let me know.
Good catch. Looks like maybe it’s in street duty mode but those main arms need to be flipped up and forward 90 degrees.Um……. @Matts440 youre sway bar isn’t doing anything at all.
Just threw them on like that after I had to put a spacer on the left tire to stop it from rubbing, will be fixed before I drive it.
When they are forward like they should be they sit straight down at the mounts. Plus I have lots of room to adjust on those connector pieces.10-4
Looks like the bearing brackets need to be moved rearward on the framerails whatever length it takes to get the aluminum sway bar links to be parallel with the frame at ride hight and new vertical links made.
