8.25 bearing issues.
Currently am rebuilding the 8.25 that came out of my Duster with a Richmond rebuild kit and Spicer Sure Grip. Main issue is that the race from the kit that sits in the housing for the carrier bearings is too large Outside Diameter. To add onto that the bearings for the carrier DO fit correctly to the Spicer carrier but are different Inside Diameter (larger) when compared to the previous factory carrier. The carrier bearing I need needs to have a 1.782 ID and the race I need needs to have a 2.891 OD. What's my issue here? Anyone ever had this problem on an A-body 8 1/4?
