8 1/4 R&P interchange
YY1
FL
I have several 8 and one quarter axles.
My 73 satellite
My 87 5th Ave parts car
A 1997 Dakota axle that was part o fa parts trade.
The Dak axle has 3.55 gears.
Will those work in either of the other housings?
IIRC [I think], the R&P will interchange in all except those with 2.41 gears. They have a different carrier.
Mike in FL
Thanks.
I read somewhere that the smaller housings were 2.41 or 2.71, and the larger housings were 2.76 and "up".
I was mostly concerned with the pinion and yoke since the application is so different.
Where you close to in FL?
I think it's 96 and earlier that you need or 27 spline, the 97 up are 29 spline.
Splines on the pinion?
No the spline count is the axle shaft so I don't know for sure how just the ring and pinion might Interchange. I was looking more at track locs and knew I needed a pre-97. Look up new ring and pinion sets for sale and see if they make 2 different parts for the year range.
