[SOLD] 8 1/4 sure grip
Mojack
Bristol, Tn.
I thought someone might need the sure grip out of this F body axle.
$250-sure grip only
$275-with 2.94 r&p
$325-you can have it all
All plus shipping, just so you know, the last complete axle i shipped was over $250 freight across country and a pain in the butt to skid. The spring perches are the isolator style and are 44 3/4 center to center. Wheel mount to wheel mount is 59 3/8. The backing plates look better than the pics but the brake hardware is incomplete. The knot head that torched the u bolts, burned a pin hole in one tube but I can weld it up no problem if you buy the housing.
Located in Bristol, TN. 37620
Hi is this still available I’m located in Murfreesboro TN been looking for a 8.25 with either 2.76 or 2.94 gear ratio
