doogievlg
I am swapping from my 7 1/4 to a 8 1/4 this week and was curious if I could use the same u bolts or will I need new ones and can I get them at any parts store?
The original U bolts will likely twist and/or break before the nut would back all the way off. They aren't supposed to be reused anyway. May as well plan to cut the U bolt in half right in the center of the top.
Yes!!! No such thing as stupid question's!!! That's what we're supposed to be here for. To help each other!!!:banghead:I got the new u bolts yesterday after work. This is a stupid question but you put a u bolt on each side of the spring perch correct ? Meaning four u bolts total.
