[SOLD] 8.25-8.75 rear near nj
mikec
hampton
looking for A body rear 323-355 gears ,posi or open or housings ,for 73 dodge dart project ,have cash waiting ,either 8.25,or 8.75 rear thanks need 4.5 on 5 spacing sorry forgot that part
I have an A-body 8 3/4 with stock axles, backing plates and drums. No center chunk. I would like $350 for it and I am in north delaware.
I have an 8.75 rear end for sale. It located in Carnegie, PA 15106 -- (Near Pittsburgh)
Out of a 72 Demon -- Abody rear end - small bolt axles - complete drum to drum - 741 center - open one-legger - I spun the wheels and estimated it is possibly a 2.76 ish gear -- PM me for price and questions.
I have a brand new in box 3: 55 gear set for 742 case $195.00 in NJ
I've got a 8.75 rear end. 741 housing. 3.23 gears. Sure grip tag on housing and gear tag 3.23. I'm just north of Louisville,Ky.
I have a clean painted 8.25 rear end with new rear disc brakes from a 98 cherokee, complete disc to disc from an original late model a body. It has highway gears and if you are interested I can deliver this. Pm for pictures and if you are serious to buy it I can take the differential cover off to verify the gear ratio. It is 5 x 4.5" bolt pattern.
The rear you have sounds good but your 4+ hours away was looking for 323-355 gears what pricing are you looking for? I like the fact of disc brakes does stock emergency brake cables work with this?
I have an A body 8-3/4 with a 741 case 3.23 sure grip. Has been drilled to 4.5" pattern. Has the spring perches moved in for the spring relocation kit, but if need be i can install new perches back in the original location but I personally think this is better to do in the car for exact location. I'm in Indianapolis but I could ship if you cover the costs.
Asking $900 complete with brakes and I believe the e-brake cables are there also
looking for A body rear 323-355 gears ,posi or open or housings ,for 73 dodge dart project ,have cash waiting ,either 8.25,or 8.75 rear thanks need 4.5 on 5 spacing ,would like to be able to check rear in person , I am in north west nj by Easton pa,
