8.25 from a -72 onto a -66 with 8.75?
NorthernSwede
Luleå, Sweden
Hi I have two darts, one -72 Swinger and one -66 4Dr
I Want to swap the 8.25 from the 72 onto the -66 and the 8.75 from the -66 onto the -72, will it be painfree?*
These are rear axles I'm talking about
you can swap them - the driveshafts are different lengths so keep them together if you can
You will most likely have to modify the driveshafts,I believe the 8.75 takes a shorter driveshaft.
Don't forget the 8.25 has a 4.5" bolt circle and the 8.75 has a 4" bolt circle (unless it was modified) for the wheels.
I am not sure but are the wheel bases of the 66 and 72 the same? If they are you should be able to swap drive shafts but if they are not then both will need to be modified.
