kdsmith07
this is a 65-67 b body housing with the perches moved to 43" to fit the a body.it measures 54 1/4" flange to flange which is only 5/8 wider than a stock a body.these work well in dusters and demons with the bigger wheel wells.it's a 742 case with oe 3.23 gears and a clutch type sure grip.has all new bearings,seal and new clutches and the small yoke.has stock bbp axles with green bearings.also has 10" backing plates and drums.950.00 and pick up only in ga.30052.pm me or [email protected] if interested,thanks
