mda440
Member
Can I reuse the collar that holds the rear wheel bearings on the axle or is it junk after being pressed on and off? If I can't reuse it, anyone know where they're available?
Also, is there supposed to be a foam gasket between the backing plate and housing or just between the axle bearing flange and backing plate? THANK YOU!
