any update on the axle fitment
are you talking about the outer seal on the axle plate or the inner seal that's in the housing?thick grease seals in 1&1/16 on each side, ( I drove em in till the outer side was just past the point where the dia narrows slightly, a slight lip) & the light bulb came on & I'm thinking that I did not drive em in far enough & that is where the interference is, further strengthened by the fact that even the SBP axles would not go in either. what do you guys think? RR
I can 3D print a seal driver that I used to set my seals in.I'm thinking that I did not drive em in far enough & that is where the interference is, further strengthened by the fact that even the SBP axles would not go in either. what do you guys think
I always use a large socket and extension as driver.. should bottom out on axle tube inner lip, reach your pinky in to check if its fully seated.the inner thick seal that is in the housing. how far should it be driven in? Dana I think I have a spray can of the right diameter (not the best contact area but seemed to work on this one). Let me check the dia of the can I think I used. RR
how far would you guestimate the seal is in there?
My seal driver sets the outer face of the seal 1.75" from the flange of the housing.
It always surprised me that there was no positive stop. There is a tool called out in the FSM but no detailsthank you D-money for the indepth on this. i didn't have the housing in front of me, but measured two when i got to the shop and they both are the same at 1.75" +/- a CH. i don't know where i came up with that 1 1/16 number, but i've subsequently edited my post
