moparfast
Hi, got a 68 Dart and want to put big bolt pattern axle shafts in the rear end my question is will I be able to use the current brake setup I have? Can I just get different brake drums or do I have to get different backing plates and drums? Its a 8 3/4 rear. It has the 5-4" pattern now want to go with 5-4 1/2 to match the disc brakes someone else has already put on the front. Thanks!
