8 3/4 axle tube ends , and a dana question
dudeman601
lawton ok
where are some places i could get a couple of 8 3/4 axle tube ends?(i am working on putting this dana together) i found them on ebay for 89 bucks, but i didnt know if what other options were out there.
also this thing has a 4.56 gear... that is a lil steep!! to change the gaer ratios , can i change the carrier? or do i need to change the whole rear end?
jegs and summit, strange axle, they all have em.
yes you probably will want to go to a street gear such as 373 or lower and you will have to change the carrier .
Buy the Moser 7400 ends if using mopar brakes. They are much better. You can still use an inner seal if you want with them.
The cheaper ends, you can get them for ~50-60 on the bag if you look. Can't use a seal in them even if you wanted. The comp eng ends mancinis sells are made by moser and are not the same as the 7400 ends.
