8 3/4 minumum width in an abody with leafs and standard shackles
Fabbr
South Dakota
Just fyi, I used 15x10 centerline auto drags with the minimum standard back spacing (I forget the measurement but its the deepest dish readily available) this is with stock hd leafs and standard shackles. The 8.75 housing measures just a hair under 44 1/8". This seems to be the minimum length without running into clearance issues with the u-bolts and the bearing flanges. The springs are relocated 3" with the outside of the relocation boxes flush with the frame. Tires are 325-50-15 et street radials with even gaps frame rail and inner quarter on each side.
