Check the wear pattern on the ring gear, it should be in the center of the tooth, (not too deep, or out near the edge). Look for burrs/chipped teeth. You can hold the ring gear, and rotate the pinion to check for excessive slop. Theres not much to go wrong with the housing, barring a serious accident, or major rust. Good luck.
