fredsmedina
6 Dart 7 MOPAR OR NOCAR
okay so i have my 8.75 rear with a 3.23 suregrip differential. i also have green bearings on this rearend
right now, its all in peices, the 2 axle shafts, the differential, and the housing.
this is my first rear end swap, so sorry if i sound "stupid", but in what order do you assemble the rear end?
do you bolt up the gears first and then put in the axle Shafts?
what all is required to put the rear end together?
and what exactly do the green bearings mean?
i'm just going to be following my 67 service manual to do the swap, in some areas its hard to understand though.
last question is, do you guys reccomend getting the whole rear end put together first and then installing it onto that car? let me know please and thanks guys!
any comments and suggestions will help me.
