schlockfink Active Member Joined Jun 15, 2012 Messages 40 Reaction score 12 Location Castro Valley California May 29, 2015 #1 I found a 8 3/4 rear end out of a 1966 barracuda. Will this guy bolt right up to my 63 dart wagon? Will I have modify anything? Paul
63dartman Well-Known Member Joined Dec 11, 2005 Messages 2,230 Reaction score 24 Location rio rancho, nm May 29, 2015 #2 If it came out of the 66 and no mods were done to the 66 it will bolt right in. Of course you need all the hardware and shock plates too.
cosgig MoBro Inc. FABO Gold Member Joined Jul 20, 2008 Messages 12,369 Reaction score 6,216 Location Pinckney, Michigan May 29, 2015 #3 And a new shorter driveshaft, unless you snagged that also!
Keith Mopar Mopar Nut Joined May 15, 2005 Messages 3,227 Reaction score 1,824 Location Calgary AB. May 29, 2015 #4 I think the drive shaft from the 66 is a slip yoke and the 63 will be a ball and trunion. So either way you have to do some cutting.
Snake Mopar Nut Joined May 22, 2006 Messages 9,454 Reaction score 491 Location Belleville Canada May 29, 2015 #5 You may need a new set of tires as well.:burnout:
