Snake
Mopar Nut
So thinking of an 8 3/4 for the duster next year.I know it small bolt.can the axles be pulled out drilled to the large bolt and the drums,i want to reuse my Cragers from the 8 1/4 rear thats in the duster now.
What about the drums.Yes. New holes should be drilled IMO and dynamically balanced.
But I purchased new axles from Dr. Diff instead. It just made it easier to do and get stronger axles for the intended build.
I have 276 with the 8 1/4 trying to find a 323-355 in great shape 8 1/4 in Canada is like pulling teeth,8 3/4 are dime a dozen.Why are you changing to an 8 3/4? If you've got an 8 1/4 and anything less than 400 hp there's really no point in switching unless you want to have a couple extra 3rd members for the 8 3/4 to swap back and forth to change the gears for different occasions.
Heck for a street only car the 8 1/4 would probably handle more than that.
And if you re-drill the SBP axles you have to use the SBP brakes still with re-drilled drums. That SBP brake stuff isn't the easiest to find all the time.
So the 8.25 is stronger than the 8 3/4No way would I change out the 8.25. It is arguable you would be backing up.
Junkyards and Dakotas...... and some years of full size pickups,I have 276 with the 8 1/4 trying to find a 323-355 in great shape 8 1/4 in Canada is like pulling teeth,8 3/4 are dime a dozen.
In the street, only the on approaching the extreme side would I say there is a difference. In mild builds, under 450, I really wouldn't worry about it in the street.I wouldn't go that far, but I don't think there's an appreciable difference one way or the other.
so what mods have to get done,can be an direct bolt in?Definitely take a look at the Dakota for a donor 3.55 or 3.90 LSD. The 3.90 is what is in my 97 Dakota with a 330 hp 318 and it has had zero issues. And it doesn't get driven easy.
kijiji go to ontario search for mopar that drive train and transmission.8 3/4 A body rear ends are a dime a dozen in Canada??? That's not the case in western Canada. Post up some links that show they plentiful in eastern Canada! There might be more 8 3/4 rears for sale than 8 1/4 rears but ALL the 8 3/4's will be more expensive than the 8 1/4's..... And it's not like the 8 1/4 sell for a nickel and the 8 3/4 sell for a dime.
A Dakota rear into a "A" body? No I do not think so. Not directly at least.
It would easier to take the gear set out and swap it over. The suregrip has a different spline count IIRC, but it is useable in the A body. Custom axles then would be needed.
