I have the axle kits with bearings studs and retaining plates green bearings for 325.00 plus shipping... takes all the head ache out of adjusting axle bearings etc too. they also can be slightly trimmed to fit if you narrow the rear some too.
aLL THE 4.5 ON 5 LUG BOLT PATTERN WILL REQUIRE THE LARGER 10" DRUMS AND BACKING PLATES. center drum register is different too which matches the 10" or larger drum brakes.
Why would you not want to switch to bigger drums for better stopping power.
Thanks,
Jim
Akron, oh
