daredevil
I recentrly pulled my 66 8.75 apart to paint and inspect and install new flange gaskets and was wondering how the axle bearings lube as there is a seal between the bearing and differential. The bearings are not later sealed green bearings they are open race bearings. Does the axle seal let lube thru to the end tube bearing and not allow water in the diff or do these older bearings need to be greased?
