805moparkid
Slant and AFX Guy
so i took it apart and layed everything thing out so it would go back together the same way but being my first time i want to make sure its right! so...
can anyone find a pic in which order the clutches go in?
should be...
dished friction(with ears)
dished steel
flat Friction(with ears)
flat steel
Flat friction(with ears)
then the piece that slides into the clutches
so is this right? and then the same for the other side?
should be...
dished steel
flat steel
