[Found!] 8.75 Rear
Mopar Tim
vista CA.
Need the 4 bolts that attach the u joint straps. Just swapped center sections, the bolts I had are to small. It looks like the ones I need have a 1/2 inch head. Mine are 7/16. Straps look ok, but they might be different as well, so might need them as well. Thanks
I would check your local napa, they should have them.
Might just be....Thanks.... No I have a different Yoke... No snap rings...
Do an ebay search for "mopar u joint strap bolts" and see if any of them look right. Not saying buy from ebay, but you might be able to figure out what you have from all the different ones listed.
