kempkan
What are the differences in the 8.75 splines for the yoke. Im trying to find a yoke for a 742 and I know the 489 will not fit but what about the 741? What size u joints did all of these come with too?
So which one would be stronger the 29 spline? I know with ratchets the fine tooth ratchet is actually stronger because it allows more teeth area to come in contact with each other. Is this the same rule on the yoke?
