Figure out a remedy and proceed or take it in the rear as it is now. Your choice.
It's a F'd up part now by his own doing ASSUMING things.
Tunnel is offset to the passanger sideDrive shaft is right up the middle of tunnel. I don't have trans in it yet but looks dead nuts center up tunnel
Yeah, I wouldn't be happy about all that. I'd be tempted to drop them back off and tell them to fix it.
Totally. I meant "fix" more from a customer service standpoint. Maybe he can offer a partial refund, or cut the long side down and move the perches over.He can't "fix" them to the initial desired length.
The builder is looking for a housing and isgoing to build a new one on his cost
Emailed Cass at Dr Diff and asked about these axles. Axle Pkg Stock Length Mopar 5X4 1/2" Bolt Pattern (pair) $298.00 Doctor Diff high-strength, 30 or 35 spline axle package. Question, are theses axles sufficient for 500+ HP?
His responce was, "I don't recommend ANY 30 spline axle for 500 hp if you drive the car hard, especially with a manual transmission. That is why NO manufacturer will warranty a 30 spline axle against twisting/breakage (Mark Williams, Strange, Moser, Currie etc...). 35 spline axles with a spool are fine, though."
Does any one have any experience with this product? I have read, even on thos forum that a stock 8.75 rear end could handle 500HP. and these are high strength axles. What are your opinons.
