IMO, I would suggest you "buy the 8 point kit", Mild Steel, from as close to "home" as you can find it. ALL cages Start as straight tubing. Your best bet is to find a local shop that can bend it for you, Saving the shipping costs. Were talking approx 100lbs of steel. The 2 US Suppliers, I can think of off hand are S&W Race cars and Competition Engineering. In an 8 point cage, I believe only the "Main Hoop" Is actually "Bent to Specs". All the other tubing is done with straight pieces and 6"x6" Plates welded to the subframe.
Hope this helps, Eric
