'86 Dodge Charger Drag or Pro Street Car
robsimmons
Slant 6 Drag Racer
Coxs Creek, KY
Posting for a freind. You can PM me and I will put you in contact with him.
Car is located in Ball Ground, GA North of Atlanta.
86 Dodge Charger tube chassis bracket car or Wild Pro Street car. 2350 LBS without driver.
Ladder bar coil over rear suspension with Ford 9" with 4.10 gear and 31 spline spool in an aluminum carrier.
Mustang II tubular front end with coil over shocks and rack and pinion. New Mustang II disc brakes and rotors on front ford Drums 11x21/2 on rear.
Car has a new glass windshield and all windows are glass and still roll up and down. Original hatch still has gas struts and electric release. Original door panels and headliner are in good shape..Black carpet. Removable trans tunnel. Only the hood is fiberglass lift off.
All new wiring. New MSD 6a , blaster coil, delay box and transbrake. Alternator and electric fan.
Air shifter for 3 speed torqueflite. New Alum radiator. New fuel cell, fuel lines and a single Holley 140 gallon pump.
Car comes with spare doors and hatch that can be lightened to remove another 100+ lbs. All head and tail lights still function. No turn signal switch. Single alum seat with current cam lock harness.
Runs very consistent 6.40's in the heat with 394 mopar sb and 904 on PUMP GAS. Has run a best of 6.33 1/8 and 10.13 1/4 in good weather footbraking and shifting at 6200 RPM's. Ran all 3 days at Bristol on Labor day weekend and never removed the hood or had to cool the car.
$6500 rolling or $12,500 turn key firm.
