[WANTED] 9 inch drum self adjusting brake SPRING (gotta be for (9 inch )
barbee6043
barbee 6043
Shepherd, Texas ( SE Tx)
Mine are MIA and NO supplier seems to have new for NINE inch setup!! Newest old yard is 6 hrs away!!!! Hoping someone has 4 of these. Like said,that spring for 10 inch is obviously too big!
YepI IF I was made out of $$, I would just change over to disc!!
Hoping someone has some lyn]ing around!?????
I know I an just adjust them ever so often by hand!!!! Been there done it, hard to remember to do!
Couldn't find just the springs, but the whole hardware kit for 9" is under $5. I took a guess and used '70 Dart as a search, not sure how much difference there is year-to-year...
1970 DODGE DART 3.7L 225cid L6 Drum Brake Hardware Kit | RockAuto
Thanks I had searched Rock and could not find that kit under many models. That spring is same fr any 9 inch shoe. They had just one kit! but found another kit under different company, just comes from 2 different warehouses!!!!! I had tried find all the parts from O Reilly but could not find that spring seperate or in a kit there!!!
Thanks for the help!!!
Hate to be the bearer of real news, but on the 6 cylinder, 9" brakes....
1963 - 1968 is one set up / kit ....
1969 - 1976 is a different set up/ kit....
1963 - 1968 are not available through regular channels / the internet....
I have the correct 1963 - 1968 combi / hardware kits & the self - adjuster kits --- Brand New ---
& Quality U.S.A. made ++ N.O.S. ++ Asbestos ++
Brake Shoes for your application.....
I have built 5-6 65 and earlier A bodies. Brakes?? If I remember right the shoe hold downs, can use either group, shoes interchange, the newer adjusters are fatter, but work. I have never had any trouble mixing parts or using the later kits on the arlier cars. This a is 62 Lancer Road Toad, it is a budget build! I really doubt any NOS parts will find its way here, but thanks anyway.
