He needs the 90* bolt for the oil filter adapter. Eddie, you do know there are two bolts, right? One has the holes drilled in it at stupid angles that make the bolt real weak and can break when you tighten it up. The other has the holes drilled right.
So is the link that scampmike posted the good 'un or the bad 'un???
