68 Coronet RT
68 GTS # 508 in Registry
If you have the clearance is it better to run a oil filter without the 90 degree adapter ? Will a shorty filter without a 90 degree adapter fit with stock exhaust manifolds and 2 1/2 inch TTI pipes.
i'm running 340 manifolds with TTI head pipes and i needed to run the 90* adapter in a 70 dart.. its tight in there... nothing wrong with the adapter. i've never had any leak issues. chrysler engineered that adapter to work with a 340 so i don't see any issues running one..
i'd have to look to remember but i'm pretty sure i have a napa gold 1069 on the car.
Napa Gold is the 1068, you can also use Wix 51085 or Napa gold 1085 which is a little shorter or go to Wal-Mart and get the Mopar MO-090 for 6 bucks. I like the MO-090 as it has 8 holes on top compared to 6 for the Wix and Napa even though Wix makes Napa and Mopar filters
yea that was a mistype.. 1068 i meant.. damn phone..
