Jay Anderson
I'm hearing that the 727 and the CSR shield will not work in my '68 Valiant without modifying the floor board. I just put a full floor pan in , so that's out. Will the 904 fit without the tight fit issue?
Thanks!got the CSR and 904 in 71 dart...71 duster and 71 demon....fits those A bodies...
Only problem I had was with the Milodon Deep Sump pan...pan would not drop down into K member cause the shield was hitting the firewall....quick mod to K member solved that
Room to spare with the 904. I have a 68 also with that shield.Thanks!
