Hi,
Hoping to tap som of the FABO expertise.
My '66 Dart GT had a 904 trans but now it has a 727. I still have the filler tube from the 904 but wonder if it will show the correct level reading in the 727.
When I insert the level stick, the "fill 1 pint" mark is right where the O-ring is, 5/8" (16mm) above the end of the tube.
Can anyone tell me if this'll work in the 727 or if I need to get a filler tube/stick specifically for the 727?
Thank you,
/Anders
Thank you,
/Anders
