904 front band
bobscuda67
Michigan
I need to buy a new direct drum band and I'm kinda confused on what to get. All the different linings there are red, brown, carbon fiber, kevlar.
Also flex, semi rigid, and rigid. What works the best? I called the tech at Trans-Go and he recommended the brown band, said it held the best. What are you guys using?
I burned my front red band and it looks like there wasn't enough line pressure so he said a TF-2 kit should fix it. Hope so!
