904 id
GeorgeH
Liberty, NC
Is there a site or link for looking up I'd #'s. Trying to figure out what year trans etc? Any help appreciated.
If you post the numbers on the pan rail, we have3 several members that have the resources to tell you what it is.
No numbers but àn 035 stamped on there. Case is painted like it's a remanned unit. Any other way of Id?
Look along the pan rail right below the shifter mechanism, then match those with this.
  • transguide.pdf
I'll go recheck and see if I can see anything else on the pan rail.
Yeah, if it hasn't been removed, you'll know it, because it's a lot of digits.
Look at the driver's side of the trans near where the linkages hook up. There are two different numbers 7-8 digits long, one of them is what you need to look up...
Believe its been tampered with the surface is machined and only a few partial numbers. Look nothing like a 727 I have here with PK#####...….
Doesn't look like it is clean in the pic , but its fairly clean
