1. Mr Shine
    Mr Shine At 12 dad said “Tear this 318 apart”.I was hooked.
    213
    50
    Jan 23, 2008
    South Texas
    Local Time:
    8:32 AM
    1985 Diplomat, 904 or whatever variant there of. Looking for a shift kit. Mancini says there isn’t one for the lockup. B&M says 10228, TransGo say TF-2 will work for LU or non LU.
    I need a firm answer, Will a shift kit work in a 904 LU or no?
    I’ve chased the threads to no avail.
    BTW, the converter says it’s a lockup.
    Step up tranny guys!
    Thanks!!
    • Like Like x 1
    • brian6pac
      brian6pac Well-Known Member
      4,880
      3304
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      9:32 AM
      Do you want the lock up? I have had great luck with the TF2, never used one on a lock up though
    • fklskv
      fklskv Well-Known Member
      1,184
      628
      Aug 14, 2011
      Lackawanna, NY
      Local Time:
      9:32 AM
      Turbo Action. 17156. Worked in my lock up. It disables the lock up function.
    • oldkimmer
      oldkimmer FABO Gold Member FABO Gold Member
      16,557
      4901
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      8:32 AM
      Trans Go TF-2 if what u may need if u want a harder shift. The B&M will work if u wand a little better than stock shifts. Kim
    • CudaFactHackJob
      CudaFactHackJob FABO Gold Member FABO Gold Member
      1,358
      478
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      8:32 AM
      Just drill out the 1-2 and 2-3 shift holes in the separator plate to at least .125.
    • Mr Shine
      213
      50
      Jan 23, 2008
      South Texas
      Local Time:
      8:32 AM
      Would like to keep the lockup if I can. Just thought if I do any highway cruising it might be good to have. I have a 727 VB at my disposal, it’s non.
    • Mr Shine
      213
      50
      Jan 23, 2008
      South Texas
      Local Time:
      8:32 AM
      Wanna scratch the tires on shifts. It’s a bit of a barge, but with the engine mods, it’s should have plenty of power.
    • Mr Shine
      213
      50
      Jan 23, 2008
      South Texas
      Local Time:
      8:32 AM
      Preferably yes
    • oldkimmer
      16,557
      4901
      Nov 11, 2006
      Local Time:
      8:32 AM
      TF-2
