OK - I made a trip to my storage trailer today to look at my core lockup transmission. Turns out (according to Mr. Hand's book) it is a 998 out of a 1980 Chrysler. Just looking at it, it is Very similar in case/tailshaft housing dimension. This is as compared to a 1965 cableshift gearbox. Should fit right in the same space.
That being said, does anyone know if that particular breed of 904 have any particular problems? it's a 4130956. It should have a lot of the upgraded parts and a 4 disc front clutch retainer as well as the wide ratio gearset. (some of the early 998's even had 5 disc clutches - but that would be too much to ask for!)
While I was messing around, I pulled the cooler line fittings off and took a look down the outlet hole. It is quite close to .250" (sits back in there a ways and I didn't have my inside mic handy) So, now I am wondering, just Why would I need to have cooler lines any larger than that??? The inside diameter of the fittings (-4 to 1/8" pipe) is even smaller - around .228 at best. I pulled a stainless AN -4 to 1/4 pipe thread adapter out of my parts bin and even it was less than .250! So - what we have here is not one, but two flow restrictor orifices. Not gonna get much, if any, better flow with larger lines. (same volume, less velocity) That being said, I will still put -6 (3/8") lines to my cooler, just because it makes me feel better. And the guy you run over will say "Wow, look at those fancy cooler lines!"
Upon closer examination, the fittings on the transmission are std 1/4"flare fittings using a 90*/ 45* seating angle - AN fittings (at least the ones I grabbed) are 37*. Cheech14, Art, R/T
