80fbody
Slowly working on my 904. Did the valve body & am rebuilding the sub-assemblies now. I've got the 5 clutches up front & kolenes with .065 with the stock wavy ring.
What's your opinion on the wavy rings? Should I go thru the work to machine the pressure plates down & run the flat ring? Or will the wave ring be ok?
Also, is there a better front clutch spring available without going to the multi-spring setup. Just trying not to get too deep $$ into this as it's my first trans build.
This build is for a 400hp smallblock dart.
Thanks.
Thanks.
