904 Shift selector & kick down lever
jacko241
St. Augustine, Florida
I would like some help figuring out what kickdown and selector lever I need. Pics show the shafts coming out of my 904, and I also posted pics of possible candidates. There is flat side on the selector shaft and the kickdown shaft, but I only see a flat side on the selector lever, the hole in the kickdown lever appears roundso I don't understand how the kickdown lever locks onto the shaft. l Thanks in advance!
You have a 904 shift lever. Also the throttle cable bracket is for a 2bbl.
OMM......Do you have a picture of A V8 4bbl throttle bracket? I changed my car over from a 318 2bbl column shift to 360 4bbl slap stik (B body).
I made the original multi down rod work but want to make it right. I have the 1 piece V8 down rod and multiple throttle brackets but don't know the applications for them.
Can anyone tell me what the purpose of the spring is on the slide style kickdown/pressure lever currently on my car is for? I noticed that the 1 piece downrod examples shown in post 7 are secured to the short shaft. I have the sliding style and can't get the pressure correct however I could use the lockable and adjustable block like on this rusty pos I have pictured. Why the spring?
edit
here is the factory diagram
Spring makes it easier to slide the block. The block should have a bolt in it to jam it against the rod. Kim
Mine had just the slide block and spring. No lock bolt. I swapped it out for a locking block with spring. Spring does nothing with the block adjusted and locked. Seems odd.
Having a difficult time getting my linkage set up correctly on my 3 piece 360 airgap knockoff, A999 and AVS2. My issue is the hard angle and length of the short rod at the transmission. All this worked on my 904 that I just swapped. I also have a 1 piece down rod that I can try but don't know what bracket to use. Can anyone help identify these brackets?
