68383GTS
Who sell stall convertors for a 1968 904 automatic? TCI list 72 - 80 transmissions only. B&M list only 727's. Wanting a 2000 stall.
I have a 1973 318 with small cam and a 1968 transmission. 373 gear rear end.You don't say what engine you are running, but as far as the 904 goes, converter fitment is all the same from 1968 up. Pilot measures 1.810, 4 mounting pads, 27 spline on the input shaft. You're not dealing with a lockup so I don't understand TCI listing only 1972 to 1980.
The converters mainly differ depending on what engine you're running.
How much stall are you looking for? As rod7515 says companies like Dynamic, TCS, Hughes, etc. can supply you with what you need, but they require information on your engine, axle ratio, tire size, what you mainly use the car for, before they can get you the converter best suited for your combination. If you're looking for a quality high stall, don't let price be your only guide, as the lower priced units are priced low for a reason.
"small cam", different folks have different definitions for such, specific cam ?I have a 1973 318 with small cam and a 1968 transmission. 373 gear rear end.
Engines make horsepower. Converters do not. A well constructed converter will take full advantage of the crank horsepower for sure, but will not increase it.
Actually, engines make torque, and HP is strictly a calculated number................Engines make horsepower. Converters do not. A well constructed converter will take full advantage of the crank horsepower for sure, but will not increase it.
